1 - 11 of 11 Posts
99 Honda Prelude SH the Radiator fans do not come!
The gauge goes to 7/8 and STILL they don't come on.
Do I change the thermostat and/or the Auxiliary Fan Switch?
Any ideas:bash
Discussion Starter #2
I think I have solved my OWN problem!
If I engage the A/C Button to Green for ON the FANS work!
I guess that's what you do to make them work and keep the compressor ON!
I will keep it FOREVER ON!
Discussion Starter #4
OK!
I know and I am going to change the Radiator Fan Relay and Condenser Fan Relay.
What else do I check?
I think I have changed or check all others!
For now the A/C button is on!
Discussion Starter #7
Honda Prelude 93-01 Auxiliary Fan Switch FAE 37773 P13 004
A-95 This switch is located in the thermostat cover?
Discussion Starter #8
I have the above switch on order and I will get it in a few days.
37240-PT0-004 I also have this Oil Pressure Switch Sending Unit Sensor Light Sender
on order also.
I am replacing ALL ENGINE Solenoids, Senders and Switches and these are the last ones.
If the above does not work any other suggestions?
1 - 11 of 11 Posts
