I just replaced my radiator, thermostat, temperature sender, thermoswitch, upper/lower hoses, radiator cap, coolant, and relay on my D16Z6. The problem is that while I was bleeding the cooling system I waited for the cooling fan to click on but it never did. The Honda service manual says that the cooling fan should kick on twice while you are bleeding the air out of the cooling system but mine never did.
I drove the car and the temperature sender is showing the needle is in the middle of the coolant gauge on the dashboard cluster. I put about 15 miles on the engine at 75mph in 4th and 5th gear and the needle never went past middle of the gauge. However, I have never seen the cooling fan go on. Should I be worried about overheating? Is there anything I can do to make sure the fan works? I attached the fan directly to the 12volt battery source and it spins freely with that power. But I have not seen it turn on while the car is sitting still......
HELP>:bash
HELP>:bash
