is the 800 to put it together only? the bigger price may also include wiring it up so that you can drive the car
yes, 800 to put it together. the bigger price is for assembly only. the car will not be brought to either shop....just the engine.Transparent said:is the 800 to put it together only? the bigger price may also include wiring it up so that you can drive the car
new pistons will be added, along with rod bolts.Snoopy said:if you want to rev the ls block higher than it's stock redline, you'll need to pay some attention to the block. have everything balanced and upgrade the rod bolts if you're using the stock ls rods. you could also take this time to throw in new pistons as well.
what elsecan i do other than having it sleeved or bored?Transparent said:new pistons and rods inst a built bottom end
