I know you've heard this over and over again but i searched and couldn't find what i wanted Here it is
Budget:2000 for know
Car-1991 CRX dx
Plan-Build for turbo
Daily Driver
Drag Racer on weekends
Hp-250 fwhp at high boost
Thanks for the help
So anything before 94 is obd0 but it is b18a correct. And OBD1 is much better anyway because of uberdata. What exactley do i need to convert-Just a 0bd0-obd1 jumper harness and what else. thanks for the help
njn63 said:
yeah, get a 94-95 motor to convert to obd1. I can't remember the ecu at the moment, whatever is stock for a LS teg. Then run uberdata when you go boosted.
i heard uberdata has a few bugs like cel light and a few others, i know that sonicetronic uses chrome and he has had no trouble out of it.
Well Uberdata is based on P72 code and since i am running A P30/28 based board it doesnt work very well. So i just use crome. But uber is great if you have a P72 code based computer.
info
Car-1991 CRX dx
Daily Driver
Thanks for the help
If u got a 200$ budget get a B16A first gen and save up for a rev hard turbo kit which you will have to email them for prices but u can get 120hp and 285ft/lbs added on, if u use the stock injectors u can run about 7psi of boost good luck wioth your swap :D
Somebody steer me in the right direction, but I've always had the impression to assume that non-vtec motors are better for boost.
If thats the case, and with your budget, shoot for a b18b defintelly. If you want to go Vtec later and you have more money saved up you can do the monsterious LS/Vtec swap. ... Why is it never called GS/Vtec?
