I recently found that there was a problem with ECU, I have a 1990 CRX SI, now if I was to switch it out with a working one, would it have to be from a 1990 CRX SI that is stick as well or does it not matter?
Also, I was looking into getting some integra (94-95) wheels which are 15x6 and I believe the OEM crx wheels are 14x5. I should be able to swap it right, just get some smaller tires if it rubs, correct?
Thanks in advance.
Matt
For the ecu any 88-91 civic si or crx si will work. I think all the civic si's were 5spd's anyways, I know for a fact if it comes out of a crx si its a 5spd. The wheels will bolt up to your car, and a 195/50-15 tire will give you the same overall tire height as your stock wheels and tires.
yeah another ecu should work fine. from the same obd. and they did make auto Si. mine is one. but its a 93.
Discussion Starter · #9 ·
Ok, I found a ECU out of a Civic SI 89', code is PM5...now according to multiple sites, the ECU should be code PM6 for an 88-91 Civic/CRX SOHC SI...now I'm assuming this wont work with it (I don't have the part yet).
