1 - 8 of 8 Posts
I noticed last year that my 99 SI rotors were larger then the EX rotors.
Has any one tried to mix and match the center hub of a 99 SI to the asembly for a 2nd Gen CRX?
saint said:
I forgot about the ABS.
Is the 91 Teg disk swap a simple press out press in deal?
Does it require a minum 15" rim?
with the ls swap you can run 14" wheels, and you should be able to just buy new calipers and rotors ( ls has a 4x100 bolt pattern)
It is a very easy swap, I bought all new stuff when I did mine, calipers, bearings, rotors, pads, and ball joints, and yes you have to run at least a 14" rim, thats why when I went to buy the new hubs and stuff i mugged the two front wheels off the integra too.
1 - 8 of 8 Posts
