If you aren't concerned with a bumpy ride you could look into R1 coilovers. They run like 125 a set. I believe the spring rates for them are pretty high. Like 450/350 front and rear respectively.
I really don't want to put any more $$ into the suspension right now. That is why I am asking about cutting a coil out.deMad10 said:If you aren't concerned with a bumpy ride you could look into R1 coilovers. They run like 125 a set. I believe the spring rates for them are pretty high. Like 450/350 front and rear respectively.
haha..no, hydros are cool man. go ask the guys in manassas.junglistgsr said:cutting your springs is the stupidest possible thing you could do short of getting hydros on your honda...wait no, its stupider
That's just asking for trouble. First, even if you just cut a little bit off, the suspension problems created from cutting springs are due to the fact that you can't cut the exact same amount off of each spring, and it doesn't take much to mess up the balance of the car like that.iLLeFFeKt CiViC said:i know cutting lowering any springs is a bad idea especially
lowering springs.
but in my opinion i think its ok if you do it just a lil bit.
i mean anything more than .75 inches is a bad idea.
your ride should not be a lot bouncier since you have
shocks that are high quality.
Second when you cut springs you are going to change the molecular structure of the metal of the springs. Molecules realign when that much heat is applied to the metal and the result is something like what happens when steel is tempered...the metal becomes stronger and more brittle. That means that you will not only mess up the balance, you'll mess up the spring rates (so you'll prolly end up with 4 different spring rates basically), and you'll increase the risk of having the extremely bad happen...springs cracking.
This stuff happens no matter how much you cut off 'cause humans are falible and fire is hot...
well i dont see how he would end up with 4 spring rates when he was gonna cut just the 2 front ones. and if you know what you are doing you can cut the same amount off of each spring.Bampf said:
Haven't had neither happen.94honda said:lx98civic-
Do you bottom out anywhere yet or scrape?
when you cut an active coil, the spring rate gets highermunkeysoup said:nooooooo, dont cut your springs. because what happens when you cut your springs is the height of your springs changes but the spring rate doesnt, so sometimes when you go over a bump your coils will run into each other, and thats not good. your ride will be alot bouncier. just save your money until you can afford coilovers.
