..... 6 coil packs going bad at once??? LOL
so true....
yeah bosch is bad just run oem - NGK or Denso.BOSCH PLUGS F-ING SUCK IN A HONDA. DO NOT RUN THEM.
95% of the cars that come into the shop with a no start or a running problem that is caused by bad spark plugs have Bosch plugs in em. And I know it's not just my experience.
Replacing your plugs is what cured your missfire, not the coil packs. 6 coil packs going bad at once??? LOL
the way u write it seems condescending.So are you suggesting that we should change our spark plugs with a brand other than bosch. and our problem will be solved?
Just pointing out a possible cause, something the average guy working on his car may not know. I've looked at dozens of hondas that have been towed in to the shop that wouldn't start to find bosch plugs to be the cause. Then when you call the customer and tell them they need new plugs they gripe that they just tuned the car up 100 or 1000 or 10,000 miles ago. Some of em get downright pissed and think we're trying to rip em off or something. A nice fresh set of ngks and they fire right up.So are you suggesting that we should change our spark plugs with a brand other than bosch. and our problem will be solved?
so did the new CAT and EGR valve replacement solve the problem?I payed the $100 to have my car diagnosed about 2 weeks ago and Honda said the catalytic converter and the EGR valve had to be replaced. They quoted me at $2150 so I just had someone else do the repairs for $600.
whats codes are those? is the timing good?ok, just finished changing the fuel filter, sensor, and pump.
the car runs smoother and more responsive when i press the gas pedal lightly. when i press the gas pedal half way down and/or all the way to the floor, the car hesitates with very poor response and the car does not speed up as it should. CEL will start blinking (and stay on if i continue to press the gas pedal). CEL will eventually turn off and go away if i stop pressing the gas and/or press the gas pedal lightly.
when the CEL stays on, i get codes P0300, P0303, 0304, and 0305, and P1399
WTF is wrong with the car?
You need to sell that piece of shit and but a Tata Nano. It's the most reliable car ever made and you won't have to replace coil packs bcuz it has points.
[/QUOTE]
you need to piss off already.
ban this fuck.
im guessing hes not very well liked around here. :heheyou need to piss off already.
ban this fuck.
Me too !!!i like it in the butt[[/IMG]
lol he's arguing with himself.. you could maybe try passing it from your left hand to your right.:dunno::ahh:taco:Jumpy: Oh my fuggin' gawd... you have to be kidding... Points? Since when do coil packs need replacing anyways? Doesn't a car need to have a little more than -1 year of production before it can be proclaimed 'reliable'?
Gimmie some of dat chit you're smoking, pleeeeeeeeeeze!
P0300 - Random Misfire Detectedwhats codes are those? is the timing good?
Piss in my mouth please
That's fuggin' awesome dude, check it out tata, one of these IT freaks is so pissed off about gettin' all of his sh!t fecked up that he's gone through and edited all of my posts, and probably all of your posts too.I like cum in the eye
