This topic has been covered hundreds of times. But don't worry, check the stickies. Be sure to read the Technical and Mechanical stickies first. Then move to the "What do you think about this?" thread.
I assume by your post that you do not mean the JDM D15B (Japenese), but the American D15 (likely the D15B7)? If this is the case, I personally would suggest a motor swap.
Either a ZC (non-VTEC DOHC)
a JDM D15B (SOHC VTEC)
a D16 from a 92-95 EX or Si (SOHC D16Z6)
or a D16 from a 96-00 EX (SOHC D16Y8)
