... most people would prefer it to be between 170 and up.what should my compression test readings be for my d15b7?
88k miles.
thanks
when oil burns it USUALLY burns blue. when waters burns it becaomes steam and usually becomes white. so more than likley its water. and if thats the case it could be the headgasket. or it could be other things. but if i were you. id go on ebay and buy an engine gasket set. its only like 50$ man. and will all fresh gaskets and rings. i know you wont have the smoking issue anymore hahaok thanks.
im having trouble with a little bit of oil burning.
i go through a few quarts a month and thought a compression test might help me find my problem.
its only white smoke so i thought the problem would be the head gasket.
when the car is at operating temp it only smokes at redline.
what do you think i need?
im pretty sure its either rings or the head gasket
