One of my spark plug wires keeps popping up/off, form the actual spark plug,any ideas what would cause this.The rubber boot on the wire looks fine,spark plug is tight.....i just hope there's not a crack some where.....
thank for any help.
im guessing your ruber thing on the top isnt on right so its causeing it to pop off, if i was you i would squeze the bottom of the spark plug wire a little then put it on and make sure the rubber thing on top is on right
werd, ill try that.......thanks.
The whole setup itself is the stock parts, its just the wire itself that aftermarket. Plus it was doing this before the wire change. I blame it on Quikstop. It all happened after I got the oil changed, which really didn't look like it was changed at all. One friend said it might be the ring is cracked, another said its a busted rubber seal where the vavles are. The car runs fine though. Which confuses me. The only time its a problem is when I go from highway driving to slow stop and go city driving, or occasionally when I hit redline, or so I believe its redline (no RPM guage).
