ok i'm going to beg to differ.
the y8 intake manifold was recommended to me by 4 different people from three different shops here in orlando and by larry from endyn. basically the reason being that the path the runners take to the head is a more direct path rather than the down and then 90 degree turn to the head the d16a6/z6 intake manifolds take.
also the port of the y8 intake manifold is the size port that endyn and dpr use for the intake ports on their d16a6 heads, so they recommend that manifold because it doesn't need any porting and is relatively cheap to purchase.
what i'm wondering is how does the y8 intake manifold provide more bottom end when the runners are more open and would provide less airflow velocity at lower rpm. in my mind the larger ports of the runners would flow more air at higher rpm.
