Hey, im buying a hatchback EF from a guy, car is all set up for drag racing, it has been all gutted and has lexan windows. Here is the setup of the car:
-D16A6 block and head
-skunk 2 drag launch coilovers
-KYB adjustable struts in the front and rear
-Mickey Thompson slicks
-AEM fuel rail
-Nos/Holley fuel pressure regulator & gauge
-AEM cam gear
-Ported head
-ACT 8lb flywheel
-ACT Extreme pressure plate and disc
-NX direct port nitrous, 50-250 shot
-Nos purge kit
-Nos time based, progressive controller
-Short throw shifter
-MSD 6AL ignition
-Blaster coil, cap, and wires
-Fluidyne radiator
-Walbro 255 fuel pump
- Also that spare block and crank
Owner claims the car did a 12.31 with SRP 8.5:1 pistons, eagle rods, and a 150 shot of nitrous. Does that sound about right?
Also, the stock internals were put back in the car, and a rod went through the side of the block. The car comes with a good d16a6 block and crank, so i will be rebuilding the motor. My question is whether i should do p29 pistons and d-series rods and run like a 50 shot, which would be pretty cheap (dont have much money,) or do low compression forged internals like the previous owner did and do a 150 shot. Would the d-series rods hold up? Any help would be greatly appreciated, please keep cost in mind.
-AEM fuel rail
-AEM cam gear
-Ported head
-ACT 8lb flywheel
-Nos purge kit
-MSD 6AL ignition
-Fluidyne radiator
