about 2* retard is wgat mosy bolton cars like the most, you will lose low enf(sub 3000rpm) torqe but the car will pick up better in the top end.
also make SURE to adjust your ignition timing back to 12* BTDC after adjusting the cam(the distributer runs off the cam) once you get the cam where you want it I would say to advance ignition timing by about 2-3 degres.
this stuf yields minute gains on bolton cars and its more to get the feel/powerband you like rater then Al out hp. thats the way Ilook at it.
me personaly I like beefy mid range and good top end, low I want mpg. this is why I converted to obd1. now all I need is a burner and a wideband to dial this thing in DEAD on, when you turn the ditributer to advance you shift the whole map NOT just a specific part at WOT so basicly your car will run great at WOT if you advance it a few degrees but you may scrofice mpg down lower.
it cost me 200 bucks to get converted to obd1 to get all of the tuning gear another 200 but its a GREAT investmnt plus you can charge people for tuning if your good and you do a few cars for free to get the word out.
also you could burn chips and charge 30 bucks each on ebay
only costs like 5 bucks to buy a chip lol
