Whats up guys..pulled out my D16Z6 and swapped in a B18B1 that I am going to be boosting soon..so I am going to breakdown and sell my Z6 setup.
Specs:
1993 D16Z6:Tested compression not long before I pulled it out and the numbers were in the 160s.
Doesn't use any oil,had a slight leak at the Dizzy oring and the VTEC Solonoid oring seeped a bit. Ran very good with no noises. I ran this engine for 4 years and took care of it. I checked the valve clerances twice a year and did regular oil changes between 2500-3000 miles. Do not have the EX Engine Harness as I am using it on my LS swap.
Also have the EX Tranny. Shifted smooth and the only time it made is noises was when you were shifting hard..it would slightly grind going into 3rd gear.
Also Have:
-Alternator
-A/C Compressor
-Exedy HD Clutch
-XTC 12 1/2 Pound Flywheel
-EX Mounts and Rear Bracket
-Etc
Make me some offers..I will update this tomorrow after work with some prices and pictures.
Specs:
Also Have:
-Alternator
-A/C Compressor
-Exedy HD Clutch
-Etc
