Okay guys here's my problem... I have a 94 civic ex sedan with a D16Z6. Ive had the car for about a year and it ran great for the first 9 months. In mid November it crapped out on me. I go to the University of Northwestern Ohio in pursuit of my automotive degree. As i was pulling my car into the shop area of my class, I pushed the clutch in and it simply stalled out. I tried cranking it over and nothing happened. I determined that I had no spark and ended up replacing the distributor. This fixed the problem... for about 2 weeks. When it decided to do the exact same thing that it had prior, except when it stalled this time my tach wrapped passed the 9k mark and back around to 1k rpm although the motor was stalled at this point. I have altogether replaced the distributor, cap and rotor, ECU, main relay, plugs and wires, and have checked every part I can possibly think of that could cause a no spark condition. My timing belt is fine. Timing otherwise should be fine because it ran fine before it died. If anyone has an idea of what this might be I would greatly appreciate any info. Thanks
