ok so i took my engine apart, and i want to put new rods in. I was looking in tunertoys.com and i found eagle rods for $319 and tunertoy rods for $249. but the tunertoy rods wont be available until december. how much HP can eagle rods handle??? and are they worth it for that price?? also, what are different types of rods?? i am looking into boosting 22psi. I need websites where i can order rods. thanks.
1 - What is 22psi? No clue how much power that is without knowing the turbo... So what is your hp goal? Your bio says a T3. From the compressor maps I've seen, a T3 @ 22psi won't work. It runs out of steam somewhere around 250hp.
2 - What else are you doing to your block? Is it sleeved?
Eagles will most likely be fine for whatever you are building.
