I've took the valve cover off my car the last week. and one of the rubber rings came off which i didnt see.. (The rubber that sits under the bolts and bolts the valve cover onto the engine)
After my top speed run on my lude yesterday.. I've came home, pop the hood, and shit... oil all over the place.. I check the dip stick.. oil still at same level.. So then i check were it came from.. I didnt see the rubber ring, and saw a gap between the bolt and the valve cover leaving a opening for oils to come out.. So i've look all over the engine bay for the rubber ring, and luckly i found it... Put it back on..
So here's my question.. my engine would be ok correct?? cause oil level on the dip stick is fine...
