Does the damper fork of an EG fit an EK? Is there a difference between the damper forks of the EK1,3,4 or 9?
Thanks
kommon_sense said:
would be best to ask this question on a european honda forum as we do not have EK's in the US. HOwever I *think* that they *are* different.
yea, well, that's more or less the question. Are all 6th gen damper forks the same and do 5th gens damper forks work on 6th gens.
well the shock part mounts in fine, its just the fork, i cant really remember, it was either too wide or to small, so it wouldnt go on the control arm. i've did this a long time ago, i've tried using it on my eg. so (if) it was too small for my eg, then you (might) be able to fit the eg into it with a couple of washers and stuff. you should try it and just see if it fits.
