I didn't see any posts on this so i thought i'd start a thread.. its interesting reading... Dart Machinery is producing finer grade B18 and B20 blocks. Anyway, just read on... i provided some more informational links toward the bottom. I think i just found a new project!!
• Dart B18 block has stock deck height, standard 81.5mm bore, optional 84.5mm bore.
• Dart B20+ block has extra-tall 8.900" (226mm) deck height, 84.5mm bore for increased displacement.
• Manufactured from aerospace quality C355-T6 virgin aluminum alloy for maximum strength and durability.
• Replaceable ductile iron dry sleeves are fully supported to reduce bore distortion andenhance ring seal.
• Closed deck design increases rigidity and improves head gasket
sealing.
• Steel main caps with high-strength bolts increase bottom end strength and minimize bearing bore distortion.
• Extra large water jackets increase coolant circulation around cylinders.
• Standard piston oil sprayers reduce piston temperatures to extend life and prevent detonation.
• Dart blocks use stock components, including oil pan, oil pump, water pump, alternator, and timing belt tensioner.
http://www.dartheads.com/hondab.aspx
http://www.dartheads.com/hondah.aspx
http://www.hondatuningmagazine.com/tech/0303ht_tenaciousb/
http://www.hondatuningmagazine.com/tech/0304ht_bastardb/
sealing.
