I've done it and will say that it's a pain in the ass!! Once you take off the lower panels, center dash, glove box and instrument cluster you will see a brace running across. I ended up removing the dash, leaving this brace, but I think if you unbolt this brace you will save some time because there are screws on the back side you have to remove. I found out after so do a litttle research first so you don't do things you don't need to.
