can anyone give me some info about this engine ? d15b 87ps/l like specs because i wanna put in some pistons and cams like from the a6 ?
why would you bother wasting your time and money on something like that? Anyways, here they are.
D15B6
1493cc
4 cyl, 8 valve
SOHC
9.1:1 c.r.
PGM -FI (DPFI 88-89)
PGM-FI (MPFI 90+)
88-89 62 bhp @ 4500
90-91 70 bhp @ 4500
Redline: 6800 rpm
83 lb-ft @ 3000
D15B2
1493cc
4 cyl, 16 valve
SOHC
9.2:1 c.r.
PGM-F! (DPFI)
92 bhp @ 6000
Redline: 6800 rpm
89 lb-ft @ 4500
Honestley I'd think of something else. BTW what's an a6??
wrong engine man
those engine are old crappy engines with no vtec i wanna know about the d15 jdm 1.5 sohc vtec 130hp that similar to us 1.6 ex vtec 127hp ? and is worth it
Re: wrong engine man
One of my friends did this swap in his hatch and I believe it is rated at 135hp to the fly. The engine code is something like d15b7, and it is basically just like the ZC motor in regards to power output. This is all I know off the top of my head, but I can try and scoop up some more info later on today. :)
Whether or not the engine is worth it depends on how much you are getting it for. My friend did the swap himself and it only cost around 230 or so for the motor, while another friend of mine took it to a local shop and spent 1400. I see these motors sell for 700+ without tranny, so you be the judge.
Discussion Starter #5
dudes
i already have the jdm sohc vtec in my car and tranny jus need ecu and wire harness now i wanna jus know the specs and what parts are interchangeable from the old crx's cause people put the pistons and cams in the usdm sohc vtec and get better performance i jus need to know the specs so i know if this will work with my jdm
