1 - 13 of 13 Posts
Three questions guys.. xD
Do you guys recommend me to get front and rear sway bars and a tie bar?
and..
Should i do my alignment after or before i add my shocks and springs.
and..
Does cars with automatic work more efficiently with a short ram intake or cold?
honda accord 05 4cyl auto
id get suspension parts in this order .. Springs + Shocks or tru Coilovers .. then front upper strut bar, then front AND rear sway bars ..
muhseesuh said:
and..
after.
muhseesuh said:
and..
Your motor like colder air better .. but cold air sits in a more dangerous spot .. I seen a lot of people run no fender lining with there CAI .. THIS IS VERY DUMB .. as your filter is basically soo dirty it needs to be changed weekly.
Super Ban-Finger Mod
i'd actually get the sway bars before the strut bars...they make a much bigger impression than strut bars do....but if you're on a budget, strut bars are easier to recover from :hehe
but before you do ANYTHING at all...you should upgrade the nut behind the wheel.
www.autocross.com/evolution
Discussion Starter · #5 ·
is it hard to install shocks and springs yourself? im going to use the neuspeed springs koni shocks..
if you have the right tools and patience it's VERY easy to install suspension.
Discussion Starter · #7 ·
thanks alot man. ill check out the forums for instructions on installment..
when i had my accord i put a cheap front strut tower bar on and i was extremely supprised that i could actualy tell a differnce...
Discussion Starter · #10 ·
naw man why waste ma money if i get to learn and shit. might help me out later. actually it would. so imma suck it up. stop being a bitch and work on it xDDD i'd buy the tools though. no doubt
bet you'd be even more surprised if you put a REAL strut brace on....one w/ no joints.
no...you wanna use one for an accord. the suspension is a little different between the two cars.
1 - 13 of 13 Posts
