stfu you have no idea what you're talking about.Depends what chip you get and how much you want to spend
no chips don't do anything for your car. you have a stock del-sol. chips will only screw up your ecu. delsols come with more than one type of motor. how the hell are they gonna make a chassis specific chip? they're a scam. learn about your car before you mod itits a pcd (performance chip direct) performance chip stage 1 for 80 $. think i'll get much out of it?
it'll so something alright. make your car run like crap. if you want any type of performance from an ecu, you have to get a tune. not a bs ebay chip. those chips just lie to your ecu and tell it to dump fuel.so your saying its not gonna do a thing? hmmm...
:number1 tha man is right. :w00tzit'll so something alright. make your car run like crap. if you want any type of performance from an ecu, you have to get a tune. not a bs ebay chip. those chips just lie to your ecu and tell it to dump fuel.
don't worry about a chip. either swap your motor or boost it then get a chipped ecu with tuning softwarewow well thanks for the heads up.
no. i/h/e and cams warrant an ecu reflash/tune and that's not heavily modded. and dyno tunes are overrated. a street afr tune will suffice for most street cars not making crazy powerOne more vote of don't touch the ECU unless your car is heavily modified and you want to pay for a full dyno tune.
doing just cams isn't heavy modding depends on the type of cam. a drop in stage 1 cam form skunk2 isn't heavy modding. now if you did full head work like porting, valves, retainers, springs etc. that's heavy moddingI view internal geometry changes like a cam to be a heavy modification of how the engine was intended to operate. You could sleeve the block and put forged pistons and rods in but if you keep to the same CR and bore then you don't need to mess with the pcm. (mind you unless you are doing some other changes that was a waste of time)
Anything that changes your CR or head airflow will warrant a tune but I wouldn't bother with just an IHE.
