The story is that I wanted to try led replacement bulbs for my stock cluster. The problem is that LED bulbs are polarized. One "terminal" is a positive the other is ground. This is not true for the stock bulbs. You can install a stock twist on bulb in either direction and it will work. The LED must be installed in a specific manner otherwise they will not work.
Also, the backing of the cluster does not have an indicator showing what side is positive and which is negative. So, if you don't have this information you will likely have to put the bulbs in twice....or more to get them right.
I am trying to help save you guys some time while replacing the lights in your Del Sol.
There are a total of 16 T1.5 twist on bulbs in a Del Sol Si Cluster. You can change all of them or only the ones that back light the instrument cluster. I only replaced those that light the cluster not the warning lights. I tried replacing the SRS warning light, E-Brake light, oil, battery, and CEL but their color was not right so I took them out and left them stock.
I got the direct fit LED twist on bulbs from superbrightled.com
They twist on just like the stock bulb and the resistors are wired into the socket so there is no soldering required. Also, the LED bulbs have a polarity indicator dot on the side of the bulb. That indicates the positive side of the bulb.
In this picture you can see that the stock bulb is on the left. It has no polarity dot. The LED is on the right and it has a white polarity dot.
This picture shows the installation of the bulbs and shows what side the white polarity dot is facing. The red text and the x is on the side of the bulb that has the polarity dot.
In the end the mod worked out well. The lighting is better than stock and is a nice soothing white color. I will be adding LED strip lighting but I wanted to try these bulbs out to see how they work.
