1 - 20 of 23 Posts
Honda S2000 Reverse Light LED
Diode Dynamics, we carry a full line of LED bulbs, including three different levels of brightness for your Honda S2000 reverse light or backup light bulb. We carry the brightest, highest-quality bulbs on the market, which we have designed in St. Louis, Missouri. Your order will ship same day, and we're here if you need us for support and service. Every Diode Dynamics LED bulb carries with it a three-year limited warranty.
Your purchase includes two LED bulbs for perfect fitment in your Honda S2000.
Bulb Design
HP11: Four side-firing 1.5W-rated Osram LED chips, and one 5W-rated LED chip on top, which is projected by a lens for maximum effective brightness. The bulb is housed in a machined aluminum casing, which provides superior heat diffusion for long life.
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
Included in your order is TWO BULBS to fit your Honda S2000 model year.
COLOR
These LEDs illuminate in a crisp, cool, bright, white hue for maximum light output.
BRIGHTNESS
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb:
HP48: (280 lumens) Similar brightness to OEM
HP11: (310 lumens) Slightly higher brightness than OEM bulbs.
XP80: (510 lumens) Much brighter than OEM bulbs. These are bright!
Lumens. BUYER BEWARE! Most sellers just provide "calculated" lumen numbers, based on the maximum potential brightness of the LED chips on the bulb. For example, if a bulb has five 10-lumen chips, they will rate it at 50 lumens. However, this is not accurate, as the design of an LED bulb does not get rid of heat fast enough to run the LEDs at maximum.
These "calculated" lumen ratings are much, much higher than the true, measured light output, so it will look like competitors' bulbs are brighter than ours. This is because Diode Dynamics does not provide inflated "calculated" numbers; we believe it is misleading. We test the actual brightness of the bulbs in our lab, to provide real lumen output measurements. Our measurements are accurate, but they are usually much lower than the misleading "calculated" figures.
QUALITY
LED Components. Diode Dynamics uses only the highest quality LED chips in the production of its bulbs. This means only brand-name suppliers such as Epistar, Cree, Osram, and Samsung.
While Diode Dynamics bulbs may look the same as others on the market, most copycat bulbs use economy-grade LED chips in order to reduce costs. This greatly reduces the reliability and overall brightness of the bulb when you compare it to Diode Dynamics.
Construction. Although LED technology allows for extremely long bulb life, the market is flooded with cheap LED bulbs that fail prematurely due to inferior construction. The worst enemy of LEDs is excessive heat, and when bulbs are not designed properly, they do not disperse heat as well, leading to premature failure.
Off-brand, cheap bulbs exhibit poor solder uniformity, high levels of flux in the solder, uneven chip placement, low-gauge terminal wires, poor assembly, and bulbs held together with inferior adhesives. At best, solder joints will crack and fail on low-quality LEDs after a few weeks of use. In the worst case, these bulbs can damage housings as the extra flux and adhesive evaporates and creates a residue on the lens of the housing.
Diode Dynamics bulbs are produced with modern, computerized equipment, and only the best materials, to ensure complete uniformity, high quality, and long bulb life.
All Diode Dynamics products come with a 30-day satisfaction guarantee and a 3-year limited replacement warranty.
Diode Dynamics: Backup LEDs for 2000-2009 Honda S2000
Questions? Feel free to ask here, PM, email [email protected] or call us: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thank you!
Nick C.
Diode Dynamics
XP80 Output (510 lumens):
Discussion Starter #4
Bulb dimensions are being added to our listings to help customers confirm fitment for unique applications.
(921 HP36 Reverse light LED shown)
Thanks!
Discussion Starter #6
20% OFF EVERYTHING
Coupon Code: JULY4
Our biggest sale of the year starts NOW! Get 20% off ALL LED upgrades for your vehicle with coupon code, JULY4
Now is the time to upgrade your ride!
Click Here to Shop
Discount cannot be combined with other offers or any previous orders. Expires at 11:59 p.m., July 6th, 2018.
Discussion Starter #7
20% OFF EVERYTHING
Coupon Code: JULY4
Happy 4th of July!!
Click Here to Shop
Discussion Starter #8
20% OFF EVERYTHING
Coupon Code: JULY4
The Sale Continues!
Click Here to Shop
Discussion Starter #9
20% OFF EVERYTHING
Coupon Code: JULY4
Today is the last day of the sale, don't miss out!
Click Here to Shop
Discussion Starter #16
LAST CHANCE TO SAVE!!! Until 11:59 p.m. CST on 12/2/2019, you can use coupon code "BLACKFRIDAY" at checkout for 20% off your entire order of lighting upgrades, including our NEW SS3 LED Pods!!! Don't wait, this sale ends TONIGHT!
Jake H.
Diode Dynamics
Sale ends 11:59 p.m. CST on Monday 12/2/2019. Cannot be combined with other coupon codes.
Discussion Starter #19
LAST CHANCE TO SAVE!!! Until 11:59 p.m. CST on 9/8/2020, you can use coupon code "LABOR" at checkout for 15% off your entire order of lighting upgrades, including our LED Backup Bulbs!! Don't wait, this sale ends TONIGHT!
Collin
Diode Dynamics
Sale ends 11:59 p.m. CST on Tuesday, 9/8/2020. Cannot be combined with other coupon codes.
Discussion Starter #20
Don't fear the backup! Our LED replacement backup bulbs not only give you a huge increase in nighttime vision, but they also give your ride a nice, modern cool white look!
Don't forget to PM us for free USPS shipping!
-Collin
Diode Dynamics
1 - 20 of 23 Posts
