Ever wondered how to power your V1 besides the old fasion cig-lighter plug annoying coiled power cord? messy looking loose wires on your dash bored annoy you? answers were yes to me, so I began my searches.
I own a Valentine 1, so that's what I worked with. Item 00030 (Direct-Wire Power Adapter Kit)on their website. (Part Department ) I first taught it would be so hard, because it came with no instruction, but as always, I gave some time to think and I finally got the whole idea of this project. the whole work took me about 10 mins, but I doubt it would take more then 15 mins for any one.
here goes the process.
1. the Hard wiring kit.
2. Finding the Switch wires. I went thru couple of websites what tolled how to do this work, but it was in BMWs, so really didn't help alot, but I landed on this one site telling me basic color codes. (http://www.carstereo.com) what we are looking for is Ignition (+12v Switched) Yellow/Red wire. meaning it only turns on when the key is in the key hole.
You'll see this when you open up your driver-side fuse box.
but there are few other places you are able to clamp the clamp to. any red or yellow wire is what we are looking for, so I went for yellow, why? no reason.
This would be right under the steering wheel, kinda blury, but all the wire's colors show up. I pointed out few places you can clamp I spoted in the pic with red arrows.
3. Clamping the clamp. it was easy, and I looked for about 12 gauge size of wire, and I round it. pics above is what I found, and this is what it looks like clamped.
4. Now, simply plug the red's end into the clamp. time to get the black wire, which is grounding.
5. now that both red and black wires are connected, test it out before hiding the wire. and it worked for me the first time, so I didn't worry much.
6. Hiding the wires. this is the fun part, hiding the wires, makes your car much cleaner inside!! my fav part for me atleast.
plug the wire into the V1 and estimate how much you'll need, and leave some extra for feature, you might be moving the device around, so leace some extra alone. Simply push the wires up aginst the windwhield, and they sould slide right in.
The side molding poped out with out a hassle, just gently pull on it from the top edge of it.
run the wire down to fuse box, hide it well behind the plastics so that the power cord won't be in away next time you open up your fuse box again.
7. everything is connected, only thing left to do it store it right so it doesn't move around every where. I rolled up the rest of the power-cord and shoved it into a piping that was open.
