I am looking for a diy for aftermarket taillights. I have chrome housings but I want to paint them black.
search for black housing DIY.integraboss15 said:I am looking for a diy for aftermarket taillights. I have chrome housings but I want to paint them black.
google is your frekin friend. damnit.det414 said:Hey, does anyone know how to make DIY angel eyes? i remember one of my friends talking about makin em, it has something to do with aluminum foil, some stuff u can buy from walmart, and putting it in an oven for a while... i guess if no one knows, ill talk to him and post up a diy.
I just checked the links, and all of them work. don't know what you talking about.det414 said:all the links i found where dead... but ty...![]()
are you trying to paint the whole dash/side pannels/center counsole??Ballinfrogs said:Hey guys this is my first project and I am going to paint my interior plastic pieces a gloss black. My car theme is white and black and white I believe would get dirty too easy. Anyways, I see all the DIY's on this job, but I still really dont know how to remove the pieces. Any help would be nice thanks! I drive a 95 honda prelude S.
scyked said:anyone have a diy of how to install sidemarkers on an ek? and how to wire it up so that they turn on only when you turn on ur signals?
there you go. use google next time.dxmannn from d-serise.org said:http://www.d-series.org/forums/showthread.php?t=3346
The size of the hole that I cut out was 3 1/4 X 1. Make your cut outs a little smaller than this and open it up till you get a snug fit. The trailing edge of the light has a small cut out that a small flat tip screw driver can be incerted into to press clip in to remove it. I made sure that the bottom of the cut out was parallel with the top edge of the bodyside molding cut out. I covered the area with 2 layers of duct tape made a template to draw out the hole on the tape then used a razer to cut out the tape. I used a dremil tool with some heavy duty cut off blades to cut through fender. Remember cut small then open it up. Touch up the edges with touch up paint. This hole was my final measurement, I started about a 1/16" smaller.
http://home.comcast.net/~mkjeld76/sipics/CTRMarker1.jpg
http://home.comcast.net/~mkjeld76/sipics/CTRMarker2.jpg
Good Luck and take your time.
Now to wire the lights up.
1. Loosen the inner fenderwell, remove front bumper and headlights. This will give you plenty of room to make your wiring connections.
2. Get 2 3' lengths of 22 awg wire and put a female spade connector on one end of each wire. This is what will plug into back of sidemarker.
3. Use T-taps for the ground and the corner signal. I recommend cutting, soldering, heat shrink and covering with wire loom.
JDM Note: If your going for the true JDM route, you must tap into the corner signal light only. The parking light is to be disconnected from the corner lamp and routed to the street lights in the JDM headlight if you have them.
The best place to make your connections are just behind the turn signal/parking light plug on each side.
Right side (drivers side): one wire to the green/yellow wire, the other to the black wire.
Left side: one wire to the green/red wire, the other to the black wire.
Turn on the turn signals with the parking lights on and verify that the sidemarker illuminates only when signaling. Repeat the install for the other side.
Ballinfrogs said:alright thats exactly what I was looking for...only problem is that I dont know how to disconnect the power mirrors and all that on the sides, what do I do there??
Here is one for the CRX but its same basic idea.530_H22er said:hey, anyone know how to cut the slots on your 97-01 oem prelude fenders for the jdm signal lights? thanks, i appreciate it
Why dont you add a seperate switch to turn it on and off?????????????Ballinfrogs said:Alright guys ive hooked it up to my car battery before, but its really annoying cause the neon stays on.. What I want is to be able to turn it on and off...can anyone give me a DIY on that, and if they do tell me to splice the wires to the headlight or sumthing, can they tell me the exact wires and what not, thanx! I drive a 95 Prelude.
