I am finally taking the plunge and getting some AGXs with H&R sports. My question is should I buy the KYB strut mounts and boots that they sell, or can i just use the factory stuff. I have a 97' Base 5sp.
Thanks,
Tom
if you can afford it get the strut mounts...the stock ones will give you hell because youll have to possibly cut the rubber guards and remove bushings and whatnot.....at least i had that problem but not with agx. Not only that...get mounts that will allow you to adjust the strut position for better handeling.
