Ok i am running a kinda of a wild port and polished head on a LS(B18B) and 3 angle valve job also with i/h/e right now and i was told it is in need of extra fuel cuz its sucking in too much air cuz of the p&p and thats the reason why it is sluggish.
so my quetion is. is this true? and if it is can i just use a Adjustable Fuel Pressure Regulator? or do i need like a s-afc?
I would think so, to see more power at least, upgrade to a higher grade...
i have de same problem after i do the P&P on my engine, my A/F gauge only stays in lean mode :(, i think that i need to upgrade my fuel system, but i dont know what i need? a extra fuel pump? bigger injectors?
i set my FPR to 60psi and my A/F gauge still indicate Lean :(
what can a i do?
