1 - 10 of 10 Posts
i just removed my 128mb ram and replaced it with a 256 mb ram
now at start up i get a PFN_list_corrupt error in the bios screen.
but it works fine with my old ram in it. lets hope its just a bad ram and not my computer rejecting it.
wtf is wrong with my shit i finally got my other issue figured out and now this
Yes, RAM can get ruined with static electricity. Make sure you touch a metal surface of the case before touching the RAM or other sensitive parts of the computer.
Check if the new RAM is compatible with your motherboard.
upgrade to 256mb? :p jeez what kind of ancient puter are you using?
I just upgraded to 2gb.
Anyway a program like memtest86+ will tell you if it's bad ram. Also your motherboard may not support 256mb modules.
Discussion Starter · #7 ·
i have no clue. i had a 128mb at first and now i bought a 256 and its going that. but works fine with the 128. no error screen. but my computer says it can go up to 256 max
Discussion Starter · #8 ·
yea i havent done it. i bought it last night so im just gona exhancge it since im getting some other returns todays.
What I'm getting at is that not all ram is created equal. I've got a stick of 256 that won't work in my mom's machine if I use her onboard video (works great if I don't use the onboard video). It gets the same pfn_list_corrupt and various other errors. I popped the ram in my machine and it works great. However it could also be a power issue on the 3.3v supply from the power supply. No real way to know without experimenting.
Discussion Starter · #10 ·
yea i bought the same one again and its fine.
did u see my other problem got fix when i put a different brand wireless adapter?
thanks for all the help
1 - 10 of 10 Posts
