FRONT DOORS:
Remove plug. It simply pulls out. Remove screw from door handle. Slide assembly forward, it will then pull out. remove doorlock power cable and then rod to door latch.
Remove screw from inside door pull opening
Factory front speaker. Remove screws.
Side by side picture of factory speaker and Pioneer 1648 coaxial 6.5 speakers.
Picture of 1648 mounted using FACTORY SCREWS
Plug in speaker fits front also.
To replace the door panel, it may be easier to remove the corner trim piece. The arrows show where it is clipped in. Simply pulls out.
This is the closeup of the doorlatch handle rod. Remember to put the LOCK plastic piece back on so it does not come out accidentially
finito
