Status
Not open for further replies.
1 - 10 of 10 Posts
Yo i was just woundering how double clutching wroks and how do you do it??????????????
it is not particulary useful in cars with syncros
but basically, you depress the clutch, take it into neutral, let the clutch out, give it gas to raise your revs, clutch in, throw it into gear
correct me if i'm wrong
BennySiR said:
Double clutching is only usefull in Semi's and diesels. Do not try it with your car. Unless you wanna buy a new gearbox!!:D
umm, ok. My 2nd syncro is gone and i NEED to, it dosnt hurt your car to double clutch, if anything their is a little more wear on your clutch but its saving your syncros, your not gonna need a new gear box.
sorry was confused. I though he meant shifting wiith out the clutch. I got 2 totally different things in my head screwed up. My mistake. disregard my last post.
Discussion Starter · #9 ·
cool i also heard about power shifting when u hold the gas in as u shift gears does that acctualy work cause to me it sounds it doesn't........................
1 - 10 of 10 Posts
Status
