1 - 20 of 25 Posts
Administrator
Administrator
Discussion Starter #4
1999 Si
Dc-Sports 4-2-1 vs 4-1 vs Stock
Mods: Stock
Peak HP: 139.2
Peak TQ: 100.0
Mods: DC Sports 4-2-1 header
Peak HP: 142.9
Peak TQ: 103.5
Mods: DC Sports 4-1 header
Peak HP: 140.9
Peak TQ: 104.0
Simply using an AEM filter (generic 3" pipe) w/ internal velocity stack..3.7 WHP
1st gen B16A 5-series.. bolt on's only...STOCK INTERNALS..
Max power = 154.0 ... RPM was not monitoring so no TQ reading..sorry.
sorry for the quality
Click here
I do not think B16A with stock standard can reach 154whp. is there any other mod you made?
My dyno, stock d16y7, greddy kit, rc440's, hondata s100b, flutucations in boost are from a heatsoaked turbo, 13 straight pulls
All-Motor B18C-R Civic EK9
212.3HP @ 9000 rpm 137.2 Max Torque, just incase the graph doesn't load.
Modifications:
J-Spec Type R engine(B18C)
Valve polishing
Valve seat cut & Set length adjusting
Valve rub adjusting
Cylinder head surface polishing
Port correction
Valve clearance & Valve timing adjusting
Boring & Horning
Metal measurement adjusting
Crank shaft dynamic balance
Oil pan baffle
JUN/Cosworth Super piston kit(12:1 Compression)
Type R connecting rods
JUN cam gears
JUN type 3 camshafts
JUN Titanium Retainers
JUN racing valve springs
JUN exhaust manifold
JUN type S exhaust
JUN sport ecu
DC sports intake with cold air extension
JUN hyper clutch kit
JUN light weight flywheel
Werewolf.......
Bobbo how did you achieve more torque than Horsepower? I've been checking around and that I know of hondas are pretty low on the torque meter ( compared to other cars) not saying it in a bad way. Nice pull though, how many psi's were you running?
Fixed my image link..
Anyway... I had only bolt on's on that motor.. never touched the inside.
- JDM B16A
- JDM Fields header
- Custom 2.25" Exhaust
- AEM cam sprockets
- UR - Ultra R underdrive pulley
- 310CC RC injectors
- STR fuel rail
- B&M FPR
- GSR MAP sensor
- RC overbore Throttle body
- JDM Type R IM
- 3" Custom intake short stack
- MSD plug wires
- MSD 6AL
- Iridium Denso plugs
- Noodle sports ECU
- ACT clutch
- ACT 9lbs Flywheel
- STOCK LSD
- 15" Drag radials on 15" Konig heliums..
I think that is it.. I don't remember.. it was a while ago. I have since sold the motor. Last I heard it was still running strong as ever.
1 - 20 of 25 Posts
