I replaced my evac cause the idle was jumping up and down I had a used one you can get one from a junkyard. If you want a new one let me know I work at a honda dealer ship and I get it at cost. Are you haveing trouble getting the TB out or the throttle posstioning sensor out? The TB is four bolts unhook the Throttle cable and vaccumelines. Don't for get the coolant lines on the bottom. The TPS you have to cut slits in the rivits so you can screw them out with a screw driver.
