92mm eagle crank in b18c block, can i use the original P72 rods? The pistons will be raised about 2.5mm higher since the stroke is longer? bore is standard 81mm. Anyone tried this before? let me know if there are any possible problems. thanks
Pistons will be hitting the head and valves but thats normal. Sounds like it should be pretty fast.suzukii said:92mm eagle crank in b18c block, can i use the original P72 rods? The pistons will be raised about 2.5mm higher since the stroke is longer? bore is standard 81mm. Anyone tried this before? let me know if there are any possible problems. thanks
