I have purchased a new ebrake cover. I am trying to get the old one off but it won't come off. I started using a saw to saw a side off and see if it will fall off but it didn't work as planned. What should i do?
If you are talking about a new e-brake handle cover.... the most easy way to remove the old one is to remove the assembly from the car, put it in a vise and gently tap the old handle cover off. Eventually it will slide off. That is how I did mine...Bigjhstyle said:I have purchased a new ebrake cover. I am trying to get the old one off but it won't come off. I started using a saw to saw a side off and see if it will fall off but it didn't work as planned. What should i do?
