Whats the best ecu to put on my b18c1, that will eventually have hondata s300 installed with 8psi. Should I put a obd 1 p72 in it? I have a chipped obd1 p28 that was programed for a GSR but I found out that the p28 is a SOHC ecu. Does this matter even though its chipped and programed for a b18c1? if I run this ecu will I damage the motor?
If its chipped through Hondata then its not a problem. What you need to know is if it has control over the secondary butterflies on the stock GSR IM. That is one of the main purpose of having the P72 aside from the knock sensor.
