I have a ZC ecu but it was defective and alwayz threw a code 13, well i also have a crx si ecu with the IC socket, so I took out the ZC rom and put it in the CRx si ecu, so now it runs fine and has no error codes, and has the zc fuel cut, so my question is, Does the CRX ecu with the ZC program the same as the ZC ECU?
i'm not an expert by any means but what i think you've done is installed a zc program into a crx si computer. essentially giving you an si computer with a zc program.
yea, so it should perform just like the zc would right?
