hey, i finally got my rex... 1989 hf. well here the prob.. the enigne ran great, (even thogh it a hf....gsr swap will be goin in eventually) but my friend one day decided he was gonna clean the engine. the fuckin moron shoudla asked me first. he sprayed that engine foam shit on it.. on the label it says "cover all electrical units"...well he didnt. it says "if electrical wires are not protected properly u can short ecu.....well i guess thats wat happened cause wenever i try to start the car i blow an ECU fuse..... please help me out i need to get my car runing so i can take it for body work......will this be expensive to replace the ECU or the wiring that shorted out?... any help or advice will help me out alot...thanx.....peace
I wash my engines all of the time and the only thing I cover up is the air filter. I jave never had a problem. I would let it dry out. You must have a short in your wiring for it to keep blowing the ECU fuse. The fun thing is to trace the wire down and replace it. My suggestion is to get a wiring diagram of your vehicle and see if you can trace the wire down. If not, then you will have to take it somewhere where they can do that. If you can fix it your self, it is only time consuming. A shop to fix it is another story. I had a short in my cylinder sensor wire and it took me some time to figure that is where the problem was. I just ran two new wires from the sensor to the ECU and the problem was fixed. Good luck and hope you get it running again...
