so im planning on swapping a k20a into an eg hatch or mayb a crx. ive read some on doing the swap into a crx and it can be tricky. what do i need besides mounts linkage axles and all that for this to work? any and all help is appreciated. thanks
Thorgs said:
:stupid . Also, if you use the crx, I believe that you have to cut the hood to get it to clear. The EG is an easier platform to work with, although there are issues with clearance for the power steering and you will *probably* lose A/C because there isn't much clearance between the intake manifold and front radiator support.
