OK! then what makes the air/fuel guage so bad then?? the a/f gauge is not as acurrate but whats the point if i cant tune with either?? damn should of saved my money shit.skibbs said:Something is wrong if you are running too hot or too cold, you just can't tell for sure what it is. It's a good warning device, not a tuning device. Hope this helps![]()
WrongWeaselGSR said:1450 is the temperature for stoichiometric combustion, it'll run cooler if you're rich and hotter if you're lean
Yup... You will not receive any accurate information about how to tune with an EGT guage. It is a warning device, NOT a tuning device... An A/F guage that uses a narrowband O2 sensor is NOT a tuning device... People use these gauges to alert them to problems. Wideband O2 sensors are the only accurate way to tune your A/F ratio.WeaselGSR said:That's the theoretical value
But yes, EGT will vary from engine to engine, weather, driving conditions, and A/F mixture.
On top of that, where you put your sensor will affect what temperature you get.
