Eibach vs. H & R
961 Views 3 Replies 4 Participants Last post by  smokinlx
Which would you guys go with on a 96 Civic 4 door? I'm lookin 4 about a 1.5 inch drop.
Thanx
Lance
If your looking for a 1.5inch drop go with the Eibach pro-kit. The H&R sports will be slightly lower than that, but not quite as low as the sportlines.
A good strut to par them up with is the KYB/AGX's
springs?
Comptech sport!!! 1.5 and the spring rates are adjusted on the driverside front to compensate for drives weight.
just get ground control adj. that way you can change it when ever you want
