i have a 91 hf and when i go to use my blinkers they do not work from the outside of the car, you can see the arrows going from in the cluster but my corners on the outside dont work. when i unlock my doors useing my alarm they light up so i know its not the bulbs...is there anything i can look for to connect??? please help me out asap.
Rob
Check grounds.. Did it just start after the alarm was put in or what?
check the wiring for the corners......i know exactly what you mean. my front ambers dont light up at nite but when i use the turn signal they lite up. my front corners dont even flash when i turn on/off the alarm but they work when i use the turn signal. my wiring was pretty cool when it was all working....the clear lens and the corners light up at the same time when you flip the switch but when i tried to fix em afer one wasnt working i jes messes it all up.
Discussion Starter · #4 ·
well to be honest i bought the car with the clear corners about a month ago and the blinkers from the outside never worked so i just wanna know how to fix it so i can pass inspection and actually have blinkers.
jes pop out the corners and check the wiring
