i just did a vtec head swap. it is easy, if you have everything you need in front of you and dont break anything you could do it in a few hours. as for the wiring, in the del sol S all the wires are there for the vtec from the ecu to the wiring harness on top of the right strut tower. just get a p28 ecu and then you have to run two wires from the strut tower, one to the vtec switch and one to the vtec oil pressure sensor (this has two on it the other one goes to ground). all said and done it took me about three to four hours. depending on your car the wires might or might not be there. but they are easy to run either way. get a shop book for the torque values and tightening order of bolts. i did notice that the vtec heads seem to have longer head bolts dont mix them up or you will rip the threads out of the block when you go to torque them down
