Hi, hope you guys can help. My son (Chase) has a 90 crx si with a zc swap. We bought it with the swap but are continuing to upgrage. Our last experiment is causing some problems I think. We wrapped his hedman headers with thermo tec header insulation to get some of the heat out of the engine compartment. The heat was reduced dramatically, BUT now the car does not rev as freely from 3500 to 4200 rpm. Thinking that we may be flowing better and needing more fuel we swapped the SI ECU for a integra ECU (pg6 to pg7). This didn't help. The car pulls as strong as ever until the engine warms up and then the problem resurfaces.
Does anyone have a suggestion or similar experience? Yes I know we could try removing the header wrap but a) its a painful process and b) we would like to keep it if possible.
Thanks in advance
Thanks in advance
