My 1997 civic 16sr vtec has lost power over the last few months, now i`ve got yellow waring light on checked alarm code (it`s code 41) oxegen sensor would these cause the problems i`m having
Yes.
Also does your car idle fine? No rough idle? If it does have a rough idle, it could be a vac leak thats causing the O2 sensor to through a code.
spray004 said:
Yes.
could also be that the o2 sensor is bad.
if the pre-cat o2 sensor is bad, then that can cause some mixture problems right?
that is, if the car has two o2 sensors.
feel free to shoot me down, but after some searching this is what i came up with.
spray is right, though, check the vacuum lines first, then look into the o2 sensor. o2 sensor is more expensive than a loose hose. :rolleyes
