ok today at lunch when i got out of my car. my car was making a weird sound like air was coming out of my tire and i thought it was my tire at first so i checked it and it wasnt my tire so i poped my hood and it was coming for the head. any one have this problem before?or know what it is?
18k on the rebiult motor and like 170 on the body.
1100 miles on the oil change.
Take off your intake so you have access to the throttle body. There should be two holes on the inside wall before the butterfly on the side closest to the firewall. Put your finger over them and if one of them is sucking it is either the Fast Idle Thermo Valve(FITV), or the Idle Air Control Valve (IACV). I believe the top hole is connected to the FITV, and the bottom to the IACV. If either one of these is the problem, there is a thread somewhere that shows you how to service both valves so you dont have to spend $100 plus like i did on new ones.
