Well today i replaced my engine oil. I bought 5 Quarts(only used 4.5 of it) of oil because i was told i would be 5 Qts. Now, my friend told me that the oil level should be in between the two dots on my dipstick. I am confused because since i put it 4.5 the oil level is to or alittle above the second dot(one being higher or furthest away from the end of the dipstick.) Where should the oil level be? thanks
My engine: b16a3.
the oil level should be right at the second dot (one being higher or futhest away from the end of the dipstick).
Discussion Starter · #4 ·
ok so i checked the oil level again today and it seems i have gone over the second dot. I will drain a bit oil from the pan so that it is just under the second dot.
