basic power 110 bhpCheck this URL, i have the same car and engine.
and i had some trouble finding the specs for it
http://autoban.com.ru:8080/manual/CivHtml/2-27.htm
basicaly :
Bore and stroke : 75 x 84.5 mm (2.95 x 3.33 in.)
Type : Water-cooled, 4-stroke SOHC engine
Cylinder arrangement : Inline 4-cylinder, transverse
Displacement : 1,493 cm3 (91 cu in.)
Compression ratio : 9.0
Valve train : Belt driven, SOHC 4 valves per cylinder
i hope this helps you.
basicaly :
this civic is know as exi with engine code D15Y3 sohc 16 valves non vtec engine and it produces around 118 hp to 120 hp @6200rpm and [email protected] torqueit's from the middle east 113hp not hybrid or vtec.
Its basic power is 114 [email protected] which is 115 hp and it produces maximum horse power which is around 118 to 120 [email protected] with [email protected] torque.basic power 110 bhp
btw i've got the same car.
basically standard. no mods done yet. it's non-vtec btw.
i've been wondering in what ways can i get more power...
do i necessarily need an engine swap, or shud i go for a turbo add-on?
